Which rod 6011 or 7018
发表于 2021-9-1 00:23:40 | 显示全部楼层 |阅读模式
I am building a fireplace grate and smoker grate and was wandering which rod would be better for this project.  These are the rods that I have in the barn.  They are just regular Lincoln (Home Depot) rods.  These things will see a lot of heat and wood.  Material is 1/2" and 3/4" square stalk  Thanks in advance.
Reply:No matter which rod you use, the welds will probably outlast the mild steel for the fireplace grate.                                               MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Id use 6011s, with whip and pause, just because they wont need to be dried out, unlike the 7018s, if they've been stored in a barn.[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:I would use the 7018s if done right it gives a nicer looking weld.Vantage 300 kubota ,miller 304 xmt ,lincoln ln 25 pro , ranger 305 G, plenty of other tools of the trade to make the sparks fly.
Reply:You can use either rod, whichever you feel most comfortable welding with is best.   If your machine is ac-only, be sure the 7018 rod is ac rod.  It comes in ac and dc varieties.   You can dry out the 7018 in the household oven if they've been sitting for awhile so they run better.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:As the assembled masses descended from the hillside, firebrands held aloft, weapons shining in the moonlight, the ground trembled from the weight of their leather shod feet.The awaiting army below made last wills, and sharpened their swords.............."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Kneeling behind their shields, the defending army made ready.Greek Fire was in the urns, ready for the catapault.The time was drawing near.....................Would any man be alive on the following morn to remember the preceding night."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Like a dark tide, ebbing and flowing, the two armies met.The clang of steel on steel could be heard from miles.  The sound of steel rending flesh could only be heard by the combatants, a sad sound, and one full of dread.   Despite this, the hordes pressed on, only Heaven awaited the outcome.  Mortal man no longer held sway over the events."Any day above ground is a good day"http://www.farmersamm.com/
Reply::d:d:d:d:d"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Go have another beer Samm. .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:the  dark side of ffarmersamm....
Reply:After a hogshead of ale, per DSW's suggestion............and giving credence to Weldbead's observations...........I feel it high time to retreat to yon bedchamber, and contemplate the woes of the day"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Should one count sheep............or krakin??"Any day above ground is a good day"http://www.farmersamm.com/
Reply:when i run 6010 i find myself counting circels..go run some 6010...
Reply:Originally Posted by farmersammAfter a hogshead of ale, per DSW's suggestion............and giving credence to Weldbead's observations...........I feel it high time to retreat to yon bedchamber, and contemplate the woes of the day
Reply:wow, this thread sure went downhill quickly
Reply:Naw, It got good.
GMT+8, 2025-12-22 07:55 , Processed in 0.350241 second(s), 18 queries .
