A little slow at work
发表于 2021-9-1 00:23:25 | 显示全部楼层 |阅读模式
Last week I bought some steel to build a trailer for a customer.  I also bought 500 lbs of steel to have on hand.  I had some 1/8" X 4" to play with, so I made some 4" X 4" boxes.3/32 6013 DCENTig, SP100, .023 wire, settings J8, C/25 gas.Last edited by David R; 01-26-2008 at 08:14 AM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Nice comparison of methods. What are going in the boxes?Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:Originally Posted by QuciferNice comparison of methods. What are going in the boxes?
Reply:Nice little boxes Dade. The little lincoln mig still does a nice job.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:paper clip holder/ paper weight.  what did you use to cut the metal?
Reply:6" horizontal bandsaw from harbor freight catalog in 1996.  I set the stop and just kept cutting the little pieces.  All burrs were removed as well as mill scale.David Real world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-22 07:56 , Processed in 0.094272 second(s), 18 queries .
