one job turns into another
发表于 2021-9-1 00:23:21 | 显示全部楼层 |阅读模式
do a lot of restaurant work insulation and repair workand a lot of owners ask if i do iron work they want window guards and cages for there outside ac compressors (copper is hot) so i order shop outfittersbender and attachments i think it will be here fridaywill let u know how it works and post pic.MAC Welding & FabricationPalm Bay WeldingBervard County Iron Works
Reply:Hi Ed, i heard once that you need to be cautious with window guards and lawsuits. In case of fire, you need to be able to get out. Good luck with the business growth.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:Congratulations on your new opportunities.I don't do residential bars.  I rarely, however will do commercial property because I am only barring non-opening glass.  Use your descretion.
Reply:thanks guys your advise is good real good what if i just make them and somone else installs them
Reply:They can still come after you if their lawyers are good enough.  You are insured, right?Cheers,tpwww.tompenningtonphoto.com
GMT+8, 2025-12-22 08:07 , Processed in 0.088010 second(s), 18 queries .
