Aluminum coolant line leaking
发表于 2021-9-1 00:23:21 | 显示全部楼层 |阅读模式
Rotated my tires and noticed the passenger wheel well covered in antifreeze.Opened the hood and thought it was a loose hose clamp.  Tightened it up and still dripped.  This is the line going to the heater core.  The mounting brackets both had cracks in them.You can see how nasty it was.The crack after cutting off the bracket.I welded on the other side of the existing weld to seal it. Attached Images
Reply:And welded both brackets back on.Good as new.  The dealer wanted $240.00 for this pipe.  I done this with a syncro 250 @ 70 amps.Jason Attached Images
Reply:Great aint it?  That is a tough job, well done.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Nice. www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:I've always replaced lines like that with copper. Just get some soft copper and bubble flare the ends to make hose barbs and bend it to the right shape. I then mount it with rubber-coated clamps.But what you did works fine and looks good. Great savings too!
Reply:If I could not fix it, I would have just used two nipples and a piece of heater hose.But it felt good completing the task at hand.
GMT+8, 2025-12-22 08:01 , Processed in 0.092687 second(s), 18 queries .
