What are the main resistance welding methods?
管理员
Rank: 9Rank: 9Rank: 9
发表于 2021-6-10 16:50:51 | 显示全部楼层 |阅读模式
A: there are four main resistance welding methods, namely spot welding, seam welding, projection welding and butt welding.
Pudian's main products include spot welding machine, laser welding machine, non-standard customized automatic welding machine, spot welding machine, projection welding machine, seam welding machine, butt welding machine, touch welding machine, roll welding machine, etc. It is widely used in various fields, such as auto parts nut projection welding machine, electronic and electrical industry line terminal welding, copper plate and copper wire welding, chassis distribution box welding, electronic socket switch welding, stainless steel plate, aluminum plate, galvanized plate welding
GMT+8, 2025-12-17 08:18 , Processed in 0.159029 second(s), 18 queries .
