Casters for Welding Cart
发表于 2021-9-1 00:23:14 | 显示全部楼层 |阅读模式
I have a relatively low cost welding cart for a Diversion 180 TIG welder.  The front caster wheels are each attached to the cart with four bolts.  A bolt runs through the rubber wheel on each of the casters.  By someone's design, the threads on the bolt are in contact with most of the hole in the center of the rubber wheel.  Through use, this has caused a large hole to be worn where there used to be a small hole through the center of the rubber wheel.The caster assembly no longer operates very well so I am looking at alternative for fixing or replacing the casters.   I am considering gluing a bushing in the hole in the rubber wheel.I am also considering replacing the caser with one of a different design. What might be a good caster (source and part number) for this type of application.ThanksLauran
Reply:what about drilling it out to a larger size and using a pin to avoid a repeat.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Your bushing idea is a good one, and so is Turk's suggestion.  If you decide to buy casters, look in the "welding projects" forum for a recent post with "castors" in the title.  You'll find more than enough info and suggestions on where to buy some.The casters I've bought in the past have been spec'd by wheel diameter, load range, and wheel type.  A lot of them have common bolt patterns, too.
Reply:I've used these on 5 different carts/worktables and they're great...http://www.castercity.com/cm3a-plate.htmOne caution...don't apply or release the brake with you're fingers or bare toes...those damn things bit hard!Miller 211 w/ spool gunMiller Dynasty 200DXLongevity 60i IGBT plasmaO/A w/ crappy chinese torch/gaugesSouth Bend 10K latheGrizzly 4029 10x54 millGrizzly 7x12 hor bandsawangle grnders, bench grnder, bench belt sndr7.5 hp 80gal cmprsor
GMT+8, 2025-12-22 09:42 , Processed in 0.092908 second(s), 18 queries .
