Why do the simple things take so long?
发表于 2021-9-1 00:23:05 | 显示全部楼层 |阅读模式
Man it is handy having a TIG welder.  Nice simple project of adding an electronic governor to an Onan P220.  Never though I would need to weld the throttle control arm.But I did...An entire redesign was needed.  The stock card (not much left of that now ) attached to a governor control arm that had a travel direction opposite of the new one Also the new system only has 3/4" travel, so attachment placement was very important. Attached ImagesMe!
Reply:I am a Factory Certified Onan Large Commercial Generator tech. Not that I have ever had a job as a tech...but I went to school for it! No Joke.I have never seen an electric governor.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11 Snip...I have never seen an electric governor.
Reply:I am still fine tuning the DROOP, but it works nice!  Electronic governors are common on larger gen sets, but do add $$ to the bottom line.  From no load - full load, speed it dead nuts on 2200 RPM (3600 at generator head) This unit is designed for larger engines and mounting the flywheel mag pickup was a Me!
Reply:Electronic is to Ferrari as mechanical is to Model T.
GMT+8, 2025-12-22 11:21 , Processed in 0.068334 second(s), 18 queries .
