Ok, so I'm planing on putting a lexan skin on this moldboard instead of steel skin welded. I want to brace the moldboard better because it won't have the strength of the steel skin. What type of bracing should I do? Will horizontal be enough (easy), or should I do diagonal or vertical bracing? Thanks, Nick. Attached Images
Reply:What it really needs are more of those curved braces. Make a pattern and cut em out of plate. Just my guess 5 more.DavidReal world weldin. When I grow up I want to be a tig weldor.
Reply:I'm thinkin' the same as David but..Maybe just 2 more in the middle..And keep it angled at all times..Less stress in the middle.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:The factory bracing is bent angle iron. I can do it with sheet stock. Wish I had that plasma cutter. Gonna throw in a horizontal too.
Reply:Originally Posted by Nick KentOk, so I'm planing on putting a lexan skin on this moldboard instead of steel skin welded. I want to brace the moldboard better because it won't have the strength of the steel skin. What type of bracing should I do? Will horizontal be enough (easy), or should I do diagonal or vertical bracing? Thanks, Nick.
Reply:I'm not worried about the lexan. Snoway does lexan all the time and I have a snoway plow. The bottom of the lexan is held in place by the cutting edge. The edge just covers the lexan, doesn't bolt to it. Then a top piece clamps over the top of the lexan and holds it in place. No heat required. It is only 3/16" lexan. |
