Miller trailblazer 44d help
发表于 2021-9-1 00:22:58 | 显示全部楼层 |阅读模式
I own a 1986 miller trailblazer 44d. I just recently acquired this welder a few months ago, i noticed on the front panel on the bottom right are two areas for fuses ( the type that you twist and the fuse pops out).  I pulled out one of the fuses that was fried and the only specifications on it are ( Buss MDL 6/10 125 volts)  the other fuse area contained a small metal rod. the welder starts up just fine. I looked in my manual and no where dose it have a reference for fuses on the front panel , so i went to my local welding supply stores such as airgas and praxair and neither of them could tell me the use for the fuses nor the proper replacement , according to them they should be non existent. Can you please tell me the use and proper replacement for the fuses? Any help would be greatly appreciated.  Thanks ,  Travis
Reply:Being an '86 I'd say they were the AC power outlets cartridge fuses F1 & F2 (45A/250V). Miller PN http://miller4less.com/advanced_sear...69ee8e&x=4&y=8 if you can't find them locally.Does your unit have panel mounted circuit breakers?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-22 09:41 , Processed in 0.067735 second(s), 18 queries .
