查看: 13|回复: 0
Lincoln V100-S
发表于 2021-9-1 00:22:53 | 显示全部楼层 |阅读模式
I'm new here, but have been reading a lot. I was wondering if any of you more experienced welders have any knowledge on the Lincoln Invertec V100-S welder. I have a mig welder and on oxy torch, but would like to get into tig also. I know this welder doesn't have the aluminum capability of the AC current welders,  but I could weld thinner steel with it than I can with my Mig and oxy torch. I can't really see getting something like the Precision Tig 185 anytime soon, but the V100-S is affordable now. Any help/advice is greatly appreciated. Thanks
Reply:It depends on if you see yourself doing any aluminum welding. If not then the V100 would be ideal. Of course if aluminum is important to you, I would wait and save up for the 185.  I waited a little longer than I wanted to for my setup but was glad I did. I tig more aluminum than steel.TiggerAaronHTP Invertig 201w/ CK-20 torch and Bernard ChillerHTP MicroCut 300 plasma cutterLincoln R3S-325 w/ TA 17A Wire FeederVictor Super Range II O/A kitClausing/Colchester 13X40 LatheBridgeport 9X42 Mill
GMT+8, 2025-12-22 11:22 , Processed in 0.093039 second(s), 18 queries .
