CO2 Tank Bracket w/ Pics
发表于 2021-9-1 00:22:50 | 显示全部楼层 |阅读模式
I had a friend bring by a simple design for a bracket to hold a CO2 air tank and hose in the back of his Toyota Land Cruiser.His drawing:I made a couple of suggestions to the design, the main one being adding in a few "feet" to hold the bottom on the tank:The design calls for using 1" nylon tie-down straps to secure the bottle.  I punched the oval holes for the straps:Then added some round stock to support the corner bends and provide a smooth surface for the straps to be threaded through.  This will prevent the straps from running over a sharp edge and being damaged over time:I don't have a roller at the shop so the cradles for the bottle were hand formed in a vice using a piece of pipe:Test fit:The bracket will be mounted to a metal support behind the kick panel:The bottle can be safely carried and used to inflate tires and run air tools on the trail.  The wings on the cradles will be used to hold the 25' air hose:Drive a Legend:Cheers,tpwww.tompenningtonphoto.com
Reply:I like it..Good idea with the round stock...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I like it also!!!!! nice job!!!!
Reply:good job now just needs paint
Reply:Originally Posted by prop-doctorgood job now just needs paint
Reply:nice job, well thought out too.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:Nice, I'm currently pondering how to mount a Co2 bottle in my jeep
Reply:Nice job !!!!!!
Reply:thats a great little project, your buddy should be real proud of that.You did a great job of fab and weld.G3miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:Why not compressed air rather than CO2?Nice project thou My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Originally Posted by elvergonWhy not compressed air rather than CO2?
Reply:How about the air tools, freeze your hand??
Reply:nicely done  looks good ChuckASME Pressure Vessel welder
Reply:Originally Posted by waveriderCO2 is far more efficient than regular compressed air.  The CO2 expands at an amazing rate.  A small 10 lb. bottle will fill dozens of large off-road tires.  A 20 lb. like what what is in the pictures above will last forever.Cheers,tp
Reply:Originally Posted by pulserWhere's the keg cooler mount?
Reply:Co2 is what the NASCAR guys use for their air guns on pit road !!!!  i guess if i's good enough for them ............
Reply:Originally Posted by LittleMoeCo2 is what the NASCAR guys use for their air guns on pit road !!!!  i guess if i's good enough for them ............
GMT+8, 2025-12-22 09:40 , Processed in 0.069231 second(s), 18 queries .
