Welding Cart Rear Wheel Base?
发表于 2021-9-1 00:22:47 | 显示全部楼层 |阅读模式
i am building a cart for my TA 185, and i use the big bottle.  what should the rear wheel base be for stability?  i am going to use pneumatic wheels in back and 4'' casters in the front.  the bottle will sit forward of the rear axle just a little.                thanks.  robert.
Reply:What size bottle are you using and how tall is your cart....this will need to be takin into account
Reply:the bottle is torpedo size, 10''x 5', and the shelf that the machine will sit on is about 36-42'' high.
Reply:Originally Posted by tortisi am building a cart for my TA 185, and i use the big bottle.  what should the rear wheel base be for stability?  i am going to use pneumatic wheels in back and 4'' casters in the front.  the bottle will sit forward of the rear axle just a little.                thanks.  robert.
Reply:larger wheels----easier rollingLife is tuff,so be sharp  lincoln sp 100  cutmaster101  miller bobcat  miller 250 mig  $thousands in snapon
Reply:I just built a cart for my TA-185 and cooler.  It will hold an 80 (48") or 340 (60" X 10") Cf cylinder.  I decided the same thing about using pneumatic tires.  I had a pair of 8" solid (no flat) tires rated at 300 lbs each in my hand for $13.00 each and was looking at pneumatic tires for $6.00 each.  I went with the solids because I didn't want my cart tipping over is one tire gets soft.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I used the pneumatic tire on mine as I had them on the first cart I built for my HH140....they have gotten low and needed air but never tipped over....you can pick them up @ HF on sale for $5 each......my cart holds a 160 of C25 and a 160 of argon with no problems.....it is 20" wide.....I'll post pics in a few min....Mike Attached ImagesLast edited by 84zmike; 02-10-2008 at 03:44 PM.
Reply:i went ahead and made the rear base 36'' wide.  i will go to solid tires after my next trip to tractor supply.   i'll make another thread and post todays progress.  thanks for your advice.  robert
GMT+8, 2025-12-22 09:40 , Processed in 0.093506 second(s), 18 queries .
