wear elbow
发表于 2021-9-1 00:22:47 | 显示全部楼层 |阅读模式
This is a 14 inch diameter wear elbow, is has a 1/2" replaceable back made from AR400. The square to round transition is from AR 400 -1/2 " as well. Everything else is mild steel.
Reply:how do you bend the back plate?Me!
Reply:I'd like to do stuff like that again..What's it for??...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:It's for pneumatic material conveying lines...wood material typically. This one is for a pulp mill. Actually, we built 10 of these this weekend...most of the pieces were formed and half or more of the transitions were already done as well. They have to be hardsurfaced on the inside seams. About 6 hours of welding on each. The 0.52 metal core and a 6oo amp machine help it along.
Reply:Backs are formed in the press brake ...the mild steel parts and flatbars are rolled
Reply:This is a pic of one of two cyclone collectors for the system...I didn't work on it. It's lined off on the inside with QT 100 wear  plate
Reply:Nice work. What kind of coverage gas did you use, Pure Argon?       Sincerely,             William McCormick
Reply:I see you welded the square to rounds. You didn't have a 400,000 ton press? Ha-ha.Again really nice work.       Sincerely,             William McCormick
Reply:nice dude i love stuff like that. and im guessing you used metal core?6G zirconium 702 GTAW 2" xxheavy6G P.E.D. carbon steel GTAW 2" xxheavy3G titanium Gr. 2 - Gr. 7 GTAW up to 3/4" 3G 316L stainless GTAW up to 1" 3G carbon steel GTAW up to 1" 3G Hastalloy GTAW up to 3/4"1G tantalum GTAW up to .060"
Reply:The transition was with metal core...the rest was with hard wire, 0.035" using a CO2, Argon, oxygen mix...Argoshield light. Spray transfer at about 32V.
Reply:Its always nice to see your work. Very impressive, and flawless every time.Lincoln PowerMIG 215XTLincoln Precision TIG 225Hypertherm 300
Reply:ok thought so.  looks great6G zirconium 702 GTAW 2" xxheavy6G P.E.D. carbon steel GTAW 2" xxheavy3G titanium Gr. 2 - Gr. 7 GTAW up to 3/4" 3G 316L stainless GTAW up to 1" 3G carbon steel GTAW up to 1" 3G Hastalloy GTAW up to 3/4"1G tantalum GTAW up to .060"
GMT+8, 2025-12-22 11:21 , Processed in 0.097730 second(s), 19 queries .
