Practise tig welds on 20 gauge sheet metal
发表于 2021-9-1 00:22:45 | 显示全部楼层 |阅读模式
I only have a harbor freight tig right now to play with. I am getting the Miller Syncrowave 200 sometime soon. I think I figured away to get a proper working pedal on the machine and should be starting it soon. Anyway while playing around on the tig I thought I would try and lay down a bead or two on 20 gauge sheet metal. I wish I had taken the pictures with a dime as they are very small . here is a pick of one of the beads, top and bottom. I over lapped the joint rather than butt welding it.So what do you thinkMiller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Not bad at all! Nice, actually.Try butt welding some. Believe it or not it's easier than a lap joint, but you have to have a perfect fitup.Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
Reply:Doesn't  look like SS
Reply:Originally Posted by TinbasherDoesn't  look like SS
Reply:Looks like you have it going nicelyWait untill you get a real machine.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:My first try at tig welding:Just kidding....I love the look of tig welding though.  Cant a low set mig do 20 gauge?I'm 21 and learningAvid 4wd enthusiastASE Master tech (Automotive), mechanic/fabricator by trade
Reply:Originally Posted by redhatmanCant a low set mig do 20 gauge?
Reply:Like my girlfriend said "It looks like a caterpillar"    OK, just kidding.  Looks good, burn up more filler.... You are on your way!ER70S-2 filler?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Thanks GuysI was veery happy with the welds as this is a cheap chinese welder with no foot padel or pulse. When I get the new tig its going to have both. Twisted Minds. I am planning on using 16 gauge for the tanks to allow for the thinning during shaping. I used 20 gauge because that what I had . I have a question for you. I read that you built an ewheel using ACME thread for the adjuster. I was just wondering how it worked out for you. After a lot of research, I read that ACME thread was not the best choice. I am building my adjuster for mine now.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Originally Posted by jamlitThanks GuysI was veery happy with the welds as this is a cheap chinese welder with no foot padel or pulse. When I get the new tig its going to have both. Twisted Minds. I am planning on using 16 gauge for the tanks to allow for the thinning during shaping. I used 20 gauge because that what I had . I have a question for you. I read that you built an ewheel using ACME thread for the adjuster. I was just wondering how it worked out for you. After a lot of research, I read that ACME thread was not the best choice. I am building my adjuster for mine now.
GMT+8, 2025-12-22 09:41 , Processed in 0.094392 second(s), 18 queries .
