Flux core welding
发表于 2021-9-1 00:22:34 | 显示全部楼层 |阅读模式
Hi Need some help.I was laid off several months ago from a maintenance supervisor position and have not been able to get another position.Long ago in another life, I was a welder and was nuke certified with stick & tig and can still weld & have had some experience with mig. Went for a job interview & they want me to take a flux core test.I have never done this & ASSUME it to be similar to mig.Any one with helpfull suggestions would be appreciated.Thanks
Reply:Flux core is like mig except you have a little slag to brush off, and you hold the wire at more of a straight in angle than leaning in direction of travel, with your backround  an hour of practice and you will ace it.
GMT+8, 2025-12-22 09:41 , Processed in 0.068171 second(s), 18 queries .
