fire pit progress pics
发表于 2021-9-1 00:22:32 | 显示全部楼层 |阅读模式
I'm very pleased with the way these are turning out. i know the work is slow but im doin in at school. does any one recommend a certain type or brand or paint i should use on finished pit? Attached ImagesCharliesmom
Reply:Looks good!!  I'm not sure on paint, but there is high-heat engine paint up there, and I even saw paint that withstands 1500 degrees at Ace Hardware here, I believe it's manufactured specifically for things like fire pits!  Best of luck!Have a Jeep Cherokee?  Click Here!
Reply:That really looks great. I would like to offer one suggestion; you might want to make a trap door, or pull out ash pan, to get rid of the ashes??? Maybe you can make a cool looking ash scoop to go with it. Post pic if you do. Good job. Thanks for the pics.
Reply:loking good you can use that high temp bbq paint but eventually it will burn off
Reply:Heat it dull red then rub it with beeswax.Makes a nice black finish that will last and last.Old blacksmith trick.
Reply:Looks sweet, I'd think about adding a trim strip around the top of the grate just to finish it off. I would also leave it un-pained, just bead-blast it and let it patina.
Reply:thanks for the advice, i'm not quite finished with it yet!!i iwll keep you posted!!Charliesmom
GMT+8, 2025-12-22 09:41 , Processed in 0.087496 second(s), 18 queries .
