Stars
发表于 2021-9-1 00:22:29 | 显示全部楼层 |阅读模式
I made this pice withe some .03 copper. I bent the pices, then tig welded them together. The rays are stainless rod that I welded to the copper. I changed the color of the copper alittle by heating it up with the torch. What do you guys think? Attached Images
Reply:Very nice, how did you bend the stars?grizz_____________________________________________Miller DVITD-39HF 4x6 BandsawHF Bender & Ring RollerCraftsman 12 inch Drill Press4.5 inch Grinders10 inch Metal shearAnd numerous other little goodies!!!
Reply:I think the wife would like one of these, if you don't mind I'll copy? Any chance we can get a close up of the backside?grizz_____________________________________________Miller DVITD-39HF 4x6 BandsawHF Bender & Ring RollerCraftsman 12 inch Drill Press4.5 inch Grinders10 inch Metal shearAnd numerous other little goodies!!!
Reply:I cut out triangles, then bent them on my vice with a hammer and a square punch. I don't mind if you copy it. The back side is kind of ugly. Its hard to get the two metals to weld together.
GMT+8, 2025-12-22 09:43 , Processed in 0.089812 second(s), 18 queries .
