Range Hood Ventilation Duct
发表于 2021-9-1 00:22:22 | 显示全部楼层 |阅读模式
I am remodeling my kitchen and am installing a new hood. There is quite a bit of offset between the 6" exhaust exit of the hood and the 7" exhaust pipe in my celing. The range hood sits underneath a 12" high cabinet so I need to make both an adapter and an offset pipe to connect the two. I am thinking about buying some thin stainless sheet and forming a tube and weld it in angle to accomplish the offset.Anyone else have any ideas?I don't have the exact offset dimension yet."Common sense is not very common"http://www.tahoekeyshome.com
Reply:if  for some reason yer plan craps out you could make a plenum(box) with 2 connections. either way remember this thing wil fillwith grease so if you can make cleanout provision so much the better...
Reply:Good idea about the plenum box and the cleanout. Would you get more grease in a plenum box vs just the vent tube itself because of the flow properties through the plenum box?"Common sense is not very common"http://www.tahoekeyshome.com
Reply:Originally Posted by brucebGood idea about the plenum box and the cleanout. Would you get more grease in a plenum box vs just the vent tube itself because of the flow properties through the plenum box?
Reply:Originally Posted by weldbeadi  believe every meal needs to include bacon, so i just expect a lot of grease..seriously though  flow patterns are hard to predict, but quick enough either way the walls will get a coaating and eventually they will  be" saturated "and then stuff will start to  build upand can even burn..i think codes require welded stainless...seems like the plenumdesign  might be easier to include a removable grease cleanout..
Reply:The screen/filter should catch what little grease makes it up there. You'd totally clog up the fan before you'd ever clog a 6" duct."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
GMT+8, 2025-12-22 11:00 , Processed in 0.069681 second(s), 18 queries .
