miller xmt 304 burning hot
发表于 2021-9-1 00:22:21 | 显示全部楼层 |阅读模式
When I set my xmt 304 to 150 amps and VS mode and my Hobart Hefty suitcase feeder to CV and try to run some wire it burns way too hot. When I check the amp meter it says 274 amps. Also when I put in stick mode to stick weld 7018 at 125 amps the machine also burns way too hot. If I turn it down to 50 amps it seems to run okay.Any input to this problem would be greatly appreciated.James
GMT+8, 2025-12-22 11:03 , Processed in 0.070119 second(s), 18 queries .
