general purpose welder
发表于 2021-9-1 00:22:18 | 显示全部楼层 |阅读模式
Hello everyone, I have no experience in welding and was trying to figure out what's a good general purpose welder. I just discovered that a portion of my motorcycle frame was cracked and would like to know what type of welder would be good to repair this. since it is winter and I'm not riding I figure I can do some practice before actually working on the bike. I'm also on a fixed income and don't want to spend too much on a piece of equiptment that I'm going to use only ocasionally. the body shop wants $125 just to weld one spot. so that's not an option. thanks
Reply:Let a professional perform the repair.A life is worth more than $125.00.
Reply:Originally Posted by joedirt1966Let a professional perform the repair.A life is worth more than $125.00.
Reply:thanks for the responses. the damage isn't on the main frame, just the part that holds the front cowling that encloses the headlight. thanks again
Reply:Years ago I had a crack on the upper gas tank mount for my old panhead.  The dealer welded it for me and didn't charge me a dime.If stuff like that fall off a moving bike the result just CAN'T be pretty.Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
GMT+8, 2025-12-22 11:02 , Processed in 0.069374 second(s), 18 queries .
