ThermalArc 150GTS Low current problem
发表于 2021-9-1 00:22:14 | 显示全部楼层 |阅读模式
When I strike an arc, the voltage is high enough to hold an arc at least  3/8 inches long but there is almost no current flow.  Could someone please:  Suggest what tests I can perform to isolate the failed component?Suggest a sourse of replacement parts?I am a 'mostly retired' engineer and have an array of test equipment.
GMT+8, 2025-12-22 11:02 , Processed in 0.096141 second(s), 18 queries .
