Aluminium shielding gas
发表于 2021-9-1 00:22:11 | 显示全部楼层 |阅读模式
I'd like to practice welding aluminum with a wire-feed welder.  I have a bottle of 75/25 mixture.  I know 100% argon is recommended, but has anyone tried using 75/25 on aluminum?  If so, how did it turn out?
Reply:It is like trying to run your gas engine on diesel, or running your diesel on gasoline.  It just does not work.
GMT+8, 2025-12-22 11:00 , Processed in 0.068810 second(s), 18 queries .
