mig welding questions
发表于 2021-9-1 00:22:10 | 显示全部楼层 |阅读模式
Today I was just practicing running a bead with my mig welder, using .30 flux core wire. I find that I can't pull a bead to save my life! If I push it then all looks fine. I noticed alot of little metal "balls" all over the steel plate. What causes that? too hot? wire feed too fast?
Reply:not enough heat or not enough wire speed
Reply:I turned up the wire speed! Problem solved. Thanks
GMT+8, 2025-12-22 11:03 , Processed in 0.092900 second(s), 18 queries .
