I started a thread in the tools and cutting section last week. Here are some pictures of the support bar storage box I am making out of a piece of 1/8" sheet metal.... and some of my equipment. Attached Images
Reply:The first two are of the box. The others are of my welding cart.If you look closely, you can see the haz on the box where I welded everything up. Settings on the box were wire speed of 3, voltage setting D. I turned the voltage down to C for the hinges. Attached ImagesLast edited by wicrules; 02-15-2008 at 09:52 PM.
Reply:what are you going to store in the box, and by the way, nice drill press stand
Reply:Glad it worked! Oh ya, that type of blade will make a mess. Me!
Reply:I like your spark catcher for your chop saw. If it melts its cheap and easy to replaceBrucePeople are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs. Unknown Pro Mig 175Hyphertherm 600Lots of toys at work
Reply:Mess doesn't quite describe what I have in my shop right now Between the cutting, welding, grinding, etc... I can't even see my floor.That drill press stand is a recycled sewing machine stand. It was free and I always like free.What's it going to store? Our travel trailer has a rear slide out. There are two bars which colapse down when not attached to the trailer. I am going to store those bars in the box on the rear bumper and get them out of my primary storage compartment where space is a premium.And, the welding cart and table were my first two projects with the mig....Thanks for the comments btw!Wic
Reply:I don't see any warpage. Nice Job!DavidReal world weldin. When I grow up I want to be a tig weldor.
Reply:Off topic- How does that abrasive blade work on the skil saw? Just wondering
Reply:I didn't have any problems using them on my saw. Granted, the saw's guard assembly was metal and not plastic. As many sparks as it generated, a plastic guard would have melted pretty quick.One note- I purchased a Dewalt disk and two more from Harbor Freight. The Dewalt disk was smooth and easy to use. The disk from Harbor Freight tended to vibrate and skip around a little. So, buy decent disks if you are going to do it.Wic
Reply:i hated my rockler guide. sent it back after the first run down the side.nice box though, looks good.
Reply:I like your welder cart. Nice job on the storage box too. MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Nice box. Is it long enough to hold fishing poles?Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2 |
