forge fan ideas
发表于 2021-9-1 00:22:06 | 显示全部楼层 |阅读模式
i built my own forge and i had a fan i ripped out of a dryer and i broke from all the heat of the forge. what should i use?
Reply:I bought a cheap leaf blower for 12 dollars and put a rheostat on it.works pretty good.steveBTS Welding
Reply:Squirrel cage blowers work great, I just made one as well and ordered a squirrel blower off line for about 20 bucks, went to home depot and got a dimmer switch for a light to control the air flow and it works like a champ.Last edited by Flop; 02-19-2008 at 12:04 PM.
Reply:You can haunt fleabay for a real one or you can just order a real on from centaur forge, or peih tool ect.  Both of these option are kinda spendy.  The best way I have found is to keep a lookout for one at flea markets, garage sales and estate sales.  They are built pretty tough and even a locked up one can be pulled apart, cleaned and lubed so that they work again, err... most of the time.  Or do what Flop said.
Reply:If you really want to go nuts....http://www.mervis.com/services/elect...asp?PRDID=1769--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:is it a propane forge? or coal?ChuckASME Pressure Vessel welder
GMT+8, 2025-12-22 11:02 , Processed in 0.094012 second(s), 18 queries .
