some little projects.....
发表于 2021-9-1 00:22:01 | 显示全部楼层 |阅读模式
the first pic it of a head and foot boards i made.  the other pic is of table base i made for a couple. Attached Images
Reply:Slick lookin stuff man!  Nice designs!Have a Jeep Cherokee?  Click Here!
Reply:Any tricks to bending that square tubing you used in the bedframe?  What did you do to keep the tubing from creasing, distorting, and how did you get the identical curvature on all the pieces?How did you finish the bedframe to retain the bright appearance to the steel?  Or is it aluminum?
Reply:Looks great.  I have no artistic talent.  DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Very nice.
Reply:i rolled the tubeing in a set of plate rollers a little at a time.  it is stainless steel  0.065" wall thickness and just buffed it up.
Reply:cant complain about that.  looks good63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
GMT+8, 2025-12-22 11:07 , Processed in 0.151699 second(s), 18 queries .
