Used Millermatic 185
发表于 2021-9-1 00:21:56 | 显示全部楼层 |阅读模式
Looking at a used millermatic 185 from an individual and was trying it out and while welding, after @ 3" of welding a bead the wire feed stopped. Opened up side cabinet and found a circuit breaker popped in machine. Reset breaker, welded a 3" bead, wire stopped feeding, and found breaker popped again.I'm looking for some sound advice. Does this sound like an issue on the circuit board?Thanks.
GMT+8, 2025-12-22 11:23 , Processed in 0.070282 second(s), 18 queries .
