Bending stainless flat bar
发表于 2021-9-1 00:21:55 | 显示全部楼层 |阅读模式
HelloI have to put a 30 degree bend in 5/16 x 3'' 316L flat bar and need to compromise the strength the very least possible. It is bending nicely cold in my press, Im wondering If i should be heating it or not.ThanksJoe Crecca
Reply:How wide is the bending die? A picture would help.Ian TannerKawasaki KX450 and many other fine tools
Reply:The bending will increase the strength and reduce ductility due to work hardening but the effect should be minimal or negligable with a single 30 deg bend.
GMT+8, 2025-12-22 11:11 , Processed in 0.069251 second(s), 18 queries .
