Weldpak 155 vs Migpak 15
发表于 2021-9-1 00:21:47 | 显示全部楼层 |阅读模式
Hello all:What's the difference between a Lincoln Weldpak 155  and a Lincoln  Migpak 15  (or is there one) ?In Canada, one's offerred by Canadian Tire, the other by TSC - both look the same. Thanks
Reply:The Lincoln sp175 also looks to be the same (sold by welding stores). I think the version sold by Canadian Tire, and possibly the one at TSC are not designed to be put under the same amount of stress as the sp175 (i.e. they are slightly lighter duty, using cheaper components), but I am not sure.
Reply:weldpak is a fluxcore only you would have to get the MIG upgrade. m15 is a mig and fluxcore pakage. iwould get a 175 if i were you
Reply:Originally Posted by teamnastybeastweldpak is a fluxcore only you would have to get the MIG upgrade. m15 is a mig and fluxcore pakage. iwould get a 175 if i were you
Reply:and dont get the home depot kind there not as good of quality kinda of there cheap line of lincon's. kidna like craftsman hand tools they have diffrent grades
Reply:Originally Posted by teamnastybeastand dont get the home depot kind there not as good of quality kinda of there cheap line of lincon's. kidna like craftsman hand tools they have diffrent grades
Reply:yea i never said they werent good i just said get the sp 175 cause it has better quality parts in it. they other ones are good to but the sp has grade A parts
GMT+8, 2025-12-22 11:09 , Processed in 0.094688 second(s), 18 queries .
