Diversion 180 vs squarewave 355
发表于 2021-9-1 00:21:38 | 显示全部楼层 |阅读模式
All right guys, and ladies, I was about ready to buy a diversion 180 when my bff called and told me her dad would sell me his Lincoln squarewave 355 complete for 800 dollars.  I know its kinda apples to oranges but here’s my question.  Which one of these welders will lay down a nicer bead?  I plan to do metal art, maybe some intercooler piping and turbo manifolds down the road.Will the adjustability of ac balance, and pulse make up for it being an old transformer.  Or should I go with the easy to use set it and forget it inverter based diversion.Thanks a ton, Michelle
Reply:The 355 gonna need a 125amp CB at rated output of 350ampsSure, you may not ever run it that high but I bet that machine pulls some juice just turning it on.Iffin ya got the power go for it but it is a beastThe Diversion will run on a 30amp CBEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Thats easy to answer if you have the power required. SW355 , I weld with one all the time at my day job and it is a great machine. I like the 355 better than the newer 375. The Diversion will not touch a 355 period. The machine is better than you are unless your in the top 5% of tig welders.
Reply:why waste my money on something thats over priced for what it actually is ( diversion ) get the 355 , i use a 1976 abp 360 rated 600 amps supposed to pull 250 at the wall , ive never needed to kick it into 3rd gear and i have all the power i have ever needed..... PLUS you cant stick weld with the DIVERSION lol why loose out on a complete and versitile process like that !I forgot how to change this.
Reply:I have sw355 great tig &stick machine. my pick lincoln
Reply:Dvrsyn 180Sqrwve 355City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-22 11:09 , Processed in 0.091002 second(s), 18 queries .
