a dohicky for a hand held plazma torch
发表于 2021-9-1 00:21:32 | 显示全部楼层 |阅读模式
i do most of the if up and welding of cover plates ,for this i use a hand held plaz to cut the holes for the fittings we use,and we use a lot of weld neck flanges so i need to bevel the hole so the other day i made a dohicky to heplme make the angle the same every time.ChuckASME Pressure Vessel welder
Reply:cool idea might have to try that some time63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:yup neat... will try it with my guys...Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:Cool do-hicky! I would probably call it a cutting jig. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Innovative on your part.  Making something out of nothing.Nice job.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Thats pretty cool..I made one for cutting bevels in plates kinda like that,but I like the way you mounted it right on the torch.very slick.If it's too . get an office jobLincoln wp225g7 Lincoln 250 idealarcFrankenstein O/A set-up Weld-tech  tig set-upLincoln sp 175 plus profax  arc gouger
GMT+8, 2025-12-22 11:13 , Processed in 0.215851 second(s), 18 queries .
