All Terrain Cart I'm Building need bit of help
发表于 2021-9-1 00:21:26 | 显示全部楼层 |阅读模式
I'm modeling my all terrain cart very close to this picture http://www.hobartwelders.com/weldtal...2&d=1151477047 I'm going to put a welder/generator on it as well as two tanks.The only difference is that I want to add some front handle steering like what kids have on their red wagons. I found some go cart spindles, but they are only rated for 200 pounds. I also thought of buying a flat bed cart from Northern Tool and beefing it up. Does anyone have any addtional thoughts, ideas or plans?Thanks
Reply:Build it like NASCAR!http://www.millerwelds.com/resources...2&d=1204151239http://www.millerwelds.com/resources...7&d=1204153012
Reply:TSOR:Thanks exactly what I'm talking about, but I need a clear picture so I can copy the steering set -up.
Reply:Hackwelder,find a junk riding mower or get something off greedbay. That should handle the weight without a problem. "Every choice you make will effect at least one other person"
Reply:Would this set up work Attached Images
GMT+8, 2025-12-22 12:48 , Processed in 0.101005 second(s), 18 queries .
