Taking a 220V welder to Europe. 50 vs 60 Hz
发表于 2021-9-1 00:21:20 | 显示全部楼层 |阅读模式
Hello,   This is my first post here. I have a Hobart Handler 135 and I'm about to buy a larger 220V welder, probably either a Millermatic 251 or a Lincoln Power Mig 255C.   In  a couple of years I will probably move back to Spain, where they use 220V 50Hz, instead of the 60Hz in use here. Would I be able to use this welder over there with the 10Hz difference?  Thanks,Mikel
Reply:Won't make a difference on DC.On AC, the only difference you'll notice is the sound of the arc. It will be a lower pitch.
GMT+8, 2025-12-22 11:13 , Processed in 0.105090 second(s), 18 queries .
