Titanium Filler Wire
发表于 2021-9-1 00:21:08 | 显示全部楼层 |阅读模式
I'm looking for titanium filler wire for a Ti fabrication project I'm working on.  It's  3AL/2.5V grade titanium tubing.Also if someone knows where I can buy a small amount of titanium sheet of the same grade ( 3AL/2.5V) anywhere between .04" to .1" thick will work.Thank you.
Reply:Originally Posted by IronDonutI'm looking for titanium filler wire for a Ti fabrication project I'm working on.  It's  3AL/2.5V grade titanium tubing.Also if someone knows where I can buy a small amount of titanium sheet of the same grade ( 3AL/2.5V) anywhere between .04" to .1" thick will work.Thank you.
Reply:What size filler do you need and how much ?
GMT+8, 2025-12-22 12:42 , Processed in 0.673816 second(s), 19 queries .
