How can I undo this weld?
发表于 2021-9-1 00:21:05 | 显示全部楼层 |阅读模式
Hey guys, I'm modding an iPod Photo to be something and I need to remove something that's welded on the inside.Above is a picture of an iPod Photo. That one is not mine but it looks almost exactly the same except for some minor adjustments. I have lined the inside with a soft material, already glued it in so I can't remove it. I didn't expect the bracket thing on the side to be a problem, but it is.I believe the welds used on the bracket are spot welds.How can I undo these without messing anything up?Please post with your answers, thank you.
Reply:if their just spot welds maybe you could just drill them out with the correct sized drill, being careful not to go to deep and hurt the outer cover. be careful not to get any metal in the electronics.Hope this helps Ryan_______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Reply:Originally Posted by trouble007if their just spot welds maybe you could just drill them out with the correct sized drill, being careful not to go to deep and hurt the outer cover. be careful not to get any metal in the electronics.Hope this helps Ryan
Reply:Dremel toolUnweld,,,,
Reply:Lil smuggling adventure?  Good luck!Buy American, or don't whine when you end up on the bread line.
Reply:Bomb?I'm calling the NSA1981 Lincoln SA 200Miller Trailblazer 302gMiller 211 Mig Welder w/ AutosetI'm learning to stick metal together
Reply:Air-arc, 3/8" rod minimum.  Go big or go home!"The man of great wealth owes a peculiar obligation to the State, because he derives special advantages from the mere existence of government."  Teddy RooseveltAmerican by birth, Union by choice!  Boilermakers # 60America is a Union.
Reply:Originally Posted by Bob the WelderAir-arc, 3/8" rod minimum.  Go big or go home!
Reply:First liar doesn't stand a chance!!"The man of great wealth owes a peculiar obligation to the State, because he derives special advantages from the mere existence of government."  Teddy RooseveltAmerican by birth, Union by choice!  Boilermakers # 60America is a Union.
Reply:Originally Posted by jsm11Bomb?I'm calling the NSA
Reply:LOL @ exothermic and air arcin it , i was thinkin c4 and just going out to buy a android lolI forgot how to change this.
Reply:Originally Posted by weldbeaddont waste your time..as soon as you typed it someone in fort meade read it...
Reply:Originally Posted by denrepThen go home;  exothermic burning bar.
Reply:Hydrazine---No good deed goes unpunished---
Reply:A lite touch with a 9" grinder will take it off...
Reply:Just had a second look at the pick, if you remove that bar you probably wont be able to seal the ipod back up again because that bar holds the clips from the top part.Ryan !_______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Reply:Originally Posted by Donald BranscomVery cool avatar.I also wonder what he is up to.Wonder why he did not tell us?? "to be something"  What????
Reply:got a br 22 torch you can borrow, just buy me a box of vulcan 3/8"x20" - use what you need and bring the rest back.
Reply:JB UNweldMillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC"I'd like to believe as many true things and as few false things as possible"
Reply:What could possibly be hidden in that thing?Tim Beeker.
GMT+8, 2025-12-22 11:23 , Processed in 0.095312 second(s), 18 queries .
