Something To Weld That's Not Round For A Change..
发表于 2021-9-1 00:20:58 | 显示全部楼层 |阅读模式
Little easy type job this A.M.8 10 foot long 1/8"wall 1"x2" Rectangle Tubing with some angle stock welded on one side 12" in from each end.."Keep the bottoms flat so they can be bolted to the floor"..No problem.. No Grinding Of Welds Flush Will Be Needed..Just weld in the provided area and all is well..Top...045 70S-2 filler..I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:So how did you keep the bottom flush like that? Little or no filler?Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:Originally Posted by QuciferSo how did you keep the bottom flush like that? Little or no filler?
Reply:You make it look so easy...Me!
Reply:Originally Posted by zapsterThere's filler in there..The angle stock has a "sharp" corner and the tubing has a rounded corner..Weld in the rounded corner...Pic 2.....zap!
GMT+8, 2025-12-22 11:24 , Processed in 0.068869 second(s), 18 queries .
