Tig Welding Cable
发表于 2021-9-1 00:20:53 | 显示全部楼层 |阅读模式
Hello Everyone,Brand new to the forum--looks like a very knowledgeable place to be!I have a strange question.  Does anyone know how a TIG torch cable is made, or what it looks like?  I am at the point of cutting into one...  Is the conductor IN the hose, or is a wire traveling inside, with the gas flowing in the void between it and the tubing?I need something like this for an induction heater power cable.  water will flow through the cable which has Litz wire inside.  When i design things, I try not to reinvent the wheel, and it occurred to me that TIG torch cable essentially does that.  I have a low-power ChiCom TIG, the tig torch just plugs into the machine with a twist-lock connection.  When it was new, I wondered how the electrical connection is made, then discovered that it WAS the connection.Ultimately I would like to know if those connectors have a name so I can source them.  Worst case is I can take some measurements and send them off to emachineshop.  but someone makes them, somewhere....Thanks in advance!Ragnar
Reply:welcome  have you tryed any search  like google?look for, exploded view of a TIG torch yes there is a wire  (lead) insideidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:What ChiCom torch do you have? Watercooled Or Air?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-22 12:39 , Processed in 0.085297 second(s), 18 queries .
