Ram Cart
发表于 2021-9-1 00:20:49 | 显示全部楼层 |阅读模式
Had fun today building a cart. I have posted before on the hydraulic system that feed the boiler. The hydraulic rams tend to brake a lot due to the stress they are under. We are currently trying to find the problem. So someone else build a cart which sucked for removing the rams which had four swivel casters on it, so I decided to build a new one. I could only use material I had on hand. This is what I came up with.Here are the ramsand the cartLast edited by jamlit; 03-12-2008 at 03:32 PM.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Perfect!Nothing Ever Got Done By Quitting, Never Give Up.
Reply:Very nice.I hope that soon, you won't need it!
Reply:loks good.  how is the weight distribution with a ram in there.  if its a bit of a bear to move try moving the wheels slightly back towards center more.  (if the rams are even that heavy?)
Reply:Originally Posted by mr2turbo7loks good.  how is the weight distribution with a ram in there.  if its a bit of a bear to move try moving the wheels slightly back towards center more.  (if the rams are even that heavy?)
GMT+8, 2025-12-22 12:40 , Processed in 0.070780 second(s), 18 queries .
