More Boring Welding...
发表于 2021-9-1 00:20:48 | 显示全部楼层 |阅读模式
More bores to weld today..Roller 1..Roller 1 Welded..Roller 2..Roller 2 Welded..I had to use my custom made by me cup for this..The normal size ones were a little too long and I could not get the torch to "Go where I wanted" 3" deep inside..So I used this..Now my neck is killing me from being on a funny angle while demonstrating such awesome and unbelievable welds to myself..I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Holy cow batman    !!    That positioner turned that roller ?  I know your using a steady rest... but..wow pretty neat. weld it like you own it
Reply:Originally Posted by lewrayHoly cow batman    !!    That positioner turned that roller ?  I know your using a steady rest... but..wow pretty neat.
Reply:nice looking stuff Zap... is that just MS?how did yuo custom make that cup? my guess would be just grind the ceramic away on the grinder, but i can also see that process ending in many many shards of razor-sharp ceramic all over the place.Later,Andy
Reply:good complex welding... you should set up a school... Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:Originally Posted by aczellernice looking stuff Zap... is that just MS?how did yuo custom make that cup? my guess would be just grind the ceramic away on the grinder, but i can also see that process ending in many many shards of razor-sharp ceramic all over the place.Later,Andy
Reply:Originally Posted by zapsterJust a 60 grit belt sander with a cloth belt.....zap!
Reply:You don't think much of your self do youJimmy
Reply:Originally Posted by worldsgreatestwelderYou don't think much of your self do youJimmy
Reply:OK Zap you can take the rest of the day off with pay.... Nice work.Airco 300 squarewaveMig welding center...Powcon sm300/LN 25Powcon sm200/PD lHypertherm PM 1100Miller AEAD 200LE W/LN25 FCand now another sm200 pd l combo.
Reply:I had to customize a cup the other day.  I ended up using a sharp punch to take off a good piece of it, worked great.Have we all gone mad?
Reply:I would like to know, is that a barrel out a injection molding press that you are fixing ?
Reply:Originally Posted by 560DennisI would like to know, is that a barrel out a injection molding press that you are fixing ?
GMT+8, 2025-12-22 12:40 , Processed in 0.092786 second(s), 18 queries .
