will pm255 display actual current?
发表于 2021-9-1 00:20:43 | 显示全部楼层 |阅读模式
Hi,    I'm trying my new pm-255c at different settings. The product info literaturefrom Lincoln states that the while welding, the wire feed rate display will show the actual weldiing current. Yesterday I tried to verify this statment by starting an arc and observing the wire display. It stayed solid on the feed rate and seemed never to indicate the weld current. The voltage display did seem to show the actual voltage however.    Has anyone ever observed the actual weld current on this display? Or do I have to go to "slow run in mode" to get this?                                      BrianPowerMig 255cCutmaster 51Powermax 1000 (for cnc table)Precision TIG 185 for salePrecision TIG 225
GMT+8, 2025-12-22 12:40 , Processed in 0.157801 second(s), 18 queries .
