Couple jobs from today.........
发表于 2021-9-1 00:20:41 | 显示全部楼层 |阅读模式
First I had a cylinder to break down this morning, but took a special wrench I didn't have. That' not unusual, so Time to make a wrench.  Star with some Scrap steel ofcourse.  No need to waste good steel on a wrench I probably won't use but once.Then weld up a handle, and add some 3/8" cold roll.And now we have a wrench.    I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:one job down so on to the next one........Well New Irrigation pump was installed, and needs to be hooked back up to the existing pipe.  OK  You guys know I'm not a pipe guy so go easy on me here.   the only code I have to meet is that it doesn't leak.This is the old connection.  Seems the hose just won't hold the 180psi.  It keeps blowing off and wetting the guy.  So time to start cutting...Now I have to weld the elbow back to the existing pipe.  Ran 6010 roots, and capped with 3/32" 7018I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Welding up the flanges and reducers to connect the cutoff to the check valve.  these were clean steel so I ran 6013 inside and out.Then cut a section of 6" OD galvanized, and slide into place.  I hate this stuff, but it's what the irrigation dealers gives me, so I use it.Now connected to the pump.a couple pics of the 6G.  It was only about 8 inches off the ground, but not to bad for someone who doesn't do a lot of pipe welding.  I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:And finished.  pressure checked with no leaks. I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:I love the "Making Your Own Tool" segment..I do it in a diffrent but same fashion all the time..You get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice work. You seem pretty versatile. Do you get alot of odd stuff like this, or do you just ocassionally post the fun jobs?Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:good job... no leakUnit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:Originally Posted by QuciferNice work. You seem pretty versatile. Do you get alot of odd stuff like this, or do you just ocassionally post the fun jobs?
Reply:Excellent job HammacK!John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Good work  on the pipe and pump. So these guys are pumping from that pond or whatever down below up to a field? What's that firehose affair, primer??
Reply:Nice work.  You did more pipe in a day than I do in years.   I like the 6013 welds.  When you toss that wrench or turn it into something else, you will need it again DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by SandyGood work  on the pipe and pump. So these guys are pumping from that pond or whatever down below up to a field? What's that firehose affair, primer??
Reply:jackson, i like the scorpion tail,what brand of 13 did you use, and it looks like you weaved the 6g now that ain,t easy great job either way. alan
Reply:Alan, thanks.  I try to run all of my cover passes with a weave.  The 6013's are Lincoln Fleetweld 37  3/32"  I've got three more field pipe jobs next week I'll try to get some more pics.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
GMT+8, 2025-12-22 12:45 , Processed in 0.120058 second(s), 18 queries .
