Rubber Torsion Axles
发表于 2021-9-1 00:20:40 | 显示全部楼层 |阅读模式
Do you mount your trailer bed directly to the axle? i read that the suspension is built into the axle which eliminates the need for leaf springs. seems to me that the bed would drag the ground if welded to the axle. How low do these trailers sit to the ground one they have wheels on them?
Reply:this should help explain Attached Images
Reply:http://www.dexteraxle.com/torflex_axlesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:can i just use a 4" drop axle with the leaf springs mounted under the axle to get a lower trailer?
Reply:What do you mean the bed will drag? The bed will be mounted above the axle, there is no other way. Whatever sized tires you decide to use will determine how high your trailer bed rides.Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:When I made my trailer I got some welding brackets so I could mount them to the trailer you dont want to weld on the axle it self because it would melt the rubber inside the axle.Millermatic 211 with 150 spool gunDynasty 350 Hypertherm powermax 30XP
Reply:Originally Posted by jdwcan i just use a 4" drop axle with the leaf springs mounted under the axle to get a lower trailer?
Reply:I've designed, built and repaired trailers with torsion axles.One big thing---in any given torsion axle size--the manufacturer normally offers choice of  of swing arm angles---to allow for adjustments in final frame ride height, with selected tire diameter, amount of load. This is something, you need to study and layout, prior to ordering a torsion axle.Blackbird
Reply:Do you mount your trailer bed directly to the axle? i read that the suspension is built into the axle which eliminates the need for leaf springs. seems to me that the bed would drag the ground if welded to the axle. How low do these trailers sit to the ground one they have wheels on them?
Reply:this is exactly what i want to achieve, third trailer down.http://kelleytrailers.com/Utility/utility.html
Reply:Get the torsion axles, they work well and are easy to deal with.  The ride is also nice!One other good point if you have a tandem axle trailer with leaf springs and you get a flat the other tire on that side will not ride correctly.  If you have torsions the second tire is independent and is not effected.  Now the obvious problem would be weight ratings.  But we have an emergence communications trailer that has tandem axles just for this reason.Me!
Reply:goto http://www.qtrailer.com/ and send for their catalog it'll answer most all your questionsLast edited by Magnetic Mechanic; 03-23-2008 at 11:50 PM.Reason: didn't get pic
GMT+8, 2025-12-22 12:39 , Processed in 0.113927 second(s), 18 queries .
