idealarc 300
发表于 2021-9-1 00:20:34 | 显示全部楼层 |阅读模式
what can anyone tell me about this machine? Description  (revised)    LINCOLN IDEAL ARC/ TIG 300/300 WELDER Model No. IdealArc TIG 300/300Variable Voltage AC/DC ARC Welding Power Source Serial No. AC-587071 AC/DC Arc/Tig Welder 300 Amps Capacity 32 Volt DC Output Single Phase Current Range Selector Switch Current Control Switch Adj. Spark Intensity Switch Electrode Polarity Switch After Flow Timer
Reply:You can get a full manual on it here:Lincoln Electric
Reply:thanks that helps some does anyone have this welder? or experience using one?
Reply:Originally Posted by socalgrizzthanks that helps some does anyone have this welder? or experience using one?
Reply:This is an older welder I believe. I use to own a 250(?) but not quite sure. It was an okay machine but I don't believe that it's squarewave. color was dark gray. If I remember right it was a good machine for steel and okay for aluminum. The new Lincolns now have the squarewave and they rock.........
GMT+8, 2025-12-22 12:45 , Processed in 0.039464 second(s), 17 queries .
