Layer of soot?
发表于 2021-9-1 00:20:33 | 显示全部楼层 |阅读模式
What is meant when one says "Laying down a layer of soot".  How do you do that? When do you do that? and why would you do that? Let's try it this way!!!! No, Really, It'll work...maybe.
Reply:Another question.  How long should it take to get metal flowing when welding with Oxy-Acetelene from when you first put the heat to it?Let's try it this way!!!! No, Really, It'll work...maybe.
Reply:If you have to bend or form aluminum one can remove the strength of the alloy by heating it with a torch.  It is difficult to determine temperature.  One way is to soot the surface then burn the soot off with a neutral flame.  The aluminum alloy can now be bend without cracking.
GMT+8, 2025-12-22 12:45 , Processed in 0.102697 second(s), 18 queries .
