Tube Bender, my turn
发表于 2021-9-1 00:20:31 | 显示全部楼层 |阅读模式
This is my welding table and JD2, like everybody else (almost) I am cursed with having little room. This is one of my methods to get my 15 lbs in the 5 lb bag. Attached Images
Reply:more shots. It really has worked out good. The caster wheel on the cammed pivot doesnt work as good as I would like though. Attached Images
Reply:hey we could use that idea at work, it would sure free up a big hunk of the table that i normally use. i like it.Nothing Ever Got Done By Quitting, Never Give Up.
Reply:What brand tube bender is that?It looks like the table was made for that bender, and to save space. Nice work!Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:The bender is an off the shelf JD2. Thanks for the compliments.
Reply:Thats a great Idea for a space saver. What type of hookup tools do you have for the reciever mounted under the lip?
Reply:vice, arbor press going to put a grinder on a receiver also.I have them at a couple of spots in the garage, makes the tools quite portable.
Reply:Nice, Rice.
Reply:very cool ChuckASME Pressure Vessel welder
Reply:Originally Posted by 9erNice, Rice.
GMT+8, 2025-12-22 12:47 , Processed in 0.098112 second(s), 18 queries .
