What the hell fitting is this?
发表于 2021-9-1 00:20:27 | 显示全部楼层 |阅读模式
I need to order a replacement as this hose leaks terribly. I would prefer to just get a hose barb and clamp but i cant figure out what fitting this is to order it?
Reply:gut off the brass shield with side cutters and there is a barbed end i would reuse  with a good hose clampidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Looks like the end on my inert gas hose for the mig. I usually just take the bad one in and ask for the replacement. In a pinch I've taken a zip wheel to the crimped furel, removed the existing end and just used a clamp on that after I cut off the bad part of the hose. The "barb" is smaller than those for the hose clamps but it will work..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I agree, you can cut off the brass hose ferrule and use another type of clamp or ferrule in its place.  Western Enterprises is the supplier of all welding related fittings.  The web site is not super user friendly, but you can also get a print catalog mailed to you.http://www.westernenterprises.com/
GMT+8, 2025-12-22 12:54 , Processed in 0.094510 second(s), 18 queries .
