Spot welder question
发表于 2021-9-1 00:20:27 | 显示全部楼层 |阅读模式
I have an old Peer spot welder that we have zero information about. It is a 230 volt,15KVAmodel 92. It has two dials on the side, one for current and the other is a trip dial and they are both graduated 1-5. What is the trip dial and what do the numbers represent as in a 1 settingon the current = how many amps?
Reply:I think spot welds are generally timed,  possibly 1-5 seconds for the trip dial??as far as the current dial. try measuring the weld current, I would start at a VERY low setting on the dial and a very HIGH setting on your meter  as in several HUNDRED amps full scale!fred-- fredLincoln 180C MIG
GMT+8, 2025-12-22 12:49 , Processed in 0.087828 second(s), 18 queries .
