TIG Kit advice
发表于 2021-9-1 00:20:21 | 显示全部楼层 |阅读模式
i am new to welding and want to TIG wld some Stainless Steel tubeWhich is the best make to go for ?Also who makes the best protective clothing ?including auto darkening helmet as i love my toys!thanks in advance...alanLast edited by ac427; 06-27-2005 at 09:37 AM.
Reply:Depending on material thickness and what else you may want to do with the machine, will tell which machine to get size wise. As far as a brand I would recommend Miller. They have great machines and great auto hoods just make sure you get one with 4 sensors, it will help with out of position work. Hope this helps.Brett B & B Fabrication and Welding Inc.Spalding, MI.
Reply:Thanks Brett the tube is 1 m/m to 1.5m/m thick so i guess that will affect the current required.what are slope settings used for ?  and do i need them ?
Reply:hi ac427.  i purchased the lincloln precision tig 185 with the ready pak and cart.  i love this machine, for the price i dont think it can be beat ($1650.00 with free shipping from welders-direct.com).  with the ready pak you will be all set up for tig welding stainless, just have to buy the argon.  it did not come with a stinger though which i thought was kinda cheesy, but for the money i think this is the machine for you.  oh yeah, if you need to purge the tube you will have to get a new regulator, the one that comes with it has only one output.jakeLast edited by j8khansen; 06-27-2005 at 01:56 PM.
GMT+8, 2025-12-22 12:45 , Processed in 0.093691 second(s), 18 queries .
