I really did it this time.............
发表于 2021-9-1 00:20:20 | 显示全部楼层 |阅读模式
Well I was moving my welder and ofcourse I dropped it but I ended up catching it and it only smashed the front a little bit but the the  whole connector on the gun ripped out and the 2 pins were all bent.I just bought the welder 2 weeks ago too.Do I need a new gun?its a Lincoln pro mig 180 and it has the magnum 100l gunThere looks like no other damage
Reply:Did it pull the 2 prong contactor connector from the front of the machine itself or just trash the one on the MIG torch (gun)?Miller XMT-3502 Lincoln Power Mig 140C (One w/ dedicated spoolgun)Jackson NexGen / Miller Digital EliteMiller S32P SuperWeldcraft 17fv & 9fv Tig TorchVictor & Purox O/ALincoln Ranger 9Fairly Cold Beer!!
Reply:Originally Posted by JLE-ENT.Did it pull the 2 prong contactor connector from the front of the machine itself or just trash the one on the MIG torch (gun)?
Reply:Here is a full parts list for your gun Parts ListIf I remember right, there is a set screw with a plastic nob on it that holds the gun whip into the case. That can be replaced, may need to tap the hole if the threads are damaged. The gun itself had small parts but should be fine. Hard to tell with out a picture.I didnt know the larger magnum guns would fit the small welders?
Reply:If your talking about the wired connection (which i think you are) you may need to replace the female harness and/or male. There should be parts available.Does it look like part 8 on the second page of that document?Similar to this... Mig GunLast edited by oxygen454; 12-28-2010 at 07:53 PM.
Reply:Originally Posted by oxygen454If your talking about the wired connection (which i think you are) you may need to replace the female harness and/or male. There should be parts available.Does it look like part 8 on the second page of that document?Similar to this... Mig Gun
Reply:pictures
Reply:Originally Posted by MotorMigMan15I will take pictures tommaro yes it is number 8 on the the document..........................What do I do?
Reply:Originally Posted by MarkBall2Well, take a picture & post it up, I'm having a hard time figuring out what exactly is broken.  Once we see what's broke, we can help fix it.
Reply:If you hold your curser below the pic you want to post at photobucket and click on the image code, copy it and paste it here the photo will appear in your post and people won't have to follow links. I believe you can post up to 6 per post, but you might need a minimum number of posts first to qualify.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:doh ...Not to make light of your screwup, but is there irony that you were using it during the build of a proper cart (vs sitting on a roller trash can)?
Reply:So THAT'S why da connector on the welder has guards around it!Those are the trigger leads, and if it were mine I'd shove the pins into the correct holes and put a fat blob of RTV silicone over them to secure them until I got another connector. The welding machine itself appears fine.If you had access to an organ donor gun, you could just cut and splice the wires. All you need is another plug and some lead to splice to.I chop-and-splice those at work fairly often, as I'm converting our ESABs to Tweco and generic Radnor MIG guns so all our machines use the same generic consumables. You can order the connectors, or buy something such as an adapter kit that has the pigtail to splice them.Control wire cord S26388 in the literature should be what you need.Last edited by farmall; 12-29-2010 at 04:49 PM.
Reply:Originally Posted by CurreyRdoh ...Not to make light of your screwup, but is there irony that you were using it during the build of a proper cart (vs sitting on a roller trash can)?
Reply:Originally Posted by farmallSo THAT'S why da connector on the welder has guards around it!Those are the trigger leads, and if it were mine I'd shove them into the correct holes and put a fat blob of RTV silicone over them to secure them until I got another connector. If you had access to an old gun, you could just cut and splice the wires.
Reply:Well more damage then I actully thought not only did the connector break but I guess the threads on the female end did too ............Should I just take this to a shop to be fixed
Reply:yes, I would
Reply:Should I just take this to a shop to be fixed
Reply:Ok guys sorry for being so late on this but I got it fixed and it was so easy to fix. I took it to a good friend of mine, he works at a welding repair shop and he looked at it and said yea no big deal. The 1 part was like 8 dollars(The little module in the machine) and he gave me a new connector(The one with the bent prongs) he had lying around for free.He said he would put it in for me but he said you might as well save money and do it yourself . He briefed me on basically what I had to do and I just had to take the inside cover off and swap the parts so total cost was like 10 dollars if this happens to you don't s*** the bed like I did
GMT+8, 2025-12-22 12:45 , Processed in 0.094444 second(s), 18 queries .
