Adding MIG to my Hobart 300 Amps Gas Driven
发表于 2021-9-1 00:20:19 | 显示全部楼层 |阅读模式
I would like to know what I could get with limited budget to add wire feed MIG to the Hobart GCC-300-W driven by Wisconsin gasoline engine 63 Horse Power.It has DC capability and runs like a champion. Also has 120 Volts AC outlets and two special plugs (see picture below) that I assume are for hooking up a wire feeder MIG.Can someone please give me ideas where to get something to complete the MIG arrangement and what this something should be? Please note that I am not a guru on welding or the terminology. I would be wonderful to be able to get these MIG capability when I am in the backwoods and need to do some home/project work. I have at home a 15 years old MIG welder but I would not like to disassemble parts of it to use with the Hobart since the two locations where I use them are far apart (Texas and Ontario-Canada).Thanks, Wilson
GMT+8, 2025-12-22 12:48 , Processed in 0.100069 second(s), 18 queries .
